Results 1 to 16 of 16
Thread: Help Using BC trans tool 60e
    Dec 2022
    20
    Hey guys new to this stuff and Iam trying to do just a basic tune for a 05 4.8 crew cab 4l60e I drive daily . I was trying to use the BC tool but I am obviously doing something wrong because when I put in my tire size of 31.9 275 55 20 it?s asking to shift WOT wayyy high . Any help would be greatly appreciated.
    Just realized the photo didn?t upload working on trying to get it to post
    But it’s asking 1-2 54mph and 2-3 102mph 100% throttle
    Tuner mjc79's Avatar
    Oct 2020
    Kansas
    78
    Did you add your current gear ratio in as well? If you left the "final" line alone with the 3.23 gear ratio, the numbers you posted are what the calculator puts out.
    02 Tahoe, Rebuilt 5.3, PRC 2.5 heads, BTR Stg2 V2 cam, 50lb Injectors, Speed Engineering LT's, Offroad Y, Magnaflow catback, Built 4L60, NP241 swap etc etc...
    Jan 2014
    SoCal
    1,562
    You have to do the gear/tire wizard in the "edit" tab first. Then enter the info into BC trans. The tool works great when you get used to it.
    Dec 2019
    MS
    567
    Tune and Datalog along with gear ratio and such would be helpful.
    The blue cat tool is very nice but you have to put the right info in to get the right info out.
    Dec 2022
    20
    Thanks for the reply guys . Yes the truck has a 3.23 gear in it with 20 inch Denali take offs . And yes I matched everything up in the tire wizard first on Hp tuners . Just seems like I’d be bouncing off redline WAYY before I ever saw 102 mph
    Dec 2022
    20
    Yup I sure did truck does have a 3.23 gear .
    Dec 2022
    20
    I did just seems real real high mph
    Jan 2014
    SoCal
    1,562
    Quote Originally Posted by SOTO View Post
    In the most polite possible way I can. Please tell me you didn't put the rim size in for the tire change wizard. As in 20" tall
    Dec 2022
    20
    Lol no , I put in 31.91 for total tire size since it’s a 275 55 20 . With a 3.23 gear
    Jan 2014
    SoCal
    1,562
    Cool. As a side note, never go off of what a tire says on the sidewall. Always measure with a tape measure. Almost all off road style tires are off by at least 1" and sometimes as much as 2.5".
    7,643
    If you wanna get really technical about it, there's a difference between the measurement from the ground to the top of the tire, and the actual number being used, the length of the lever, from axle c/l to the ground x 2.
    As an example, my tires claim 28.6" dia. Measured from the ground to top of the tire is 27.5". But axle to ground x 2 is 26.4".
    Dec 2022
    20
    I guess before anything I’ll TRY making the changes but … factory it’s wanting 73 mph shift and even if I take 2 inches off the tire on the bc table .. it’s still going to want almost 100mph in 2nd gear … thats what I am having a hard time believing lol
    7,643
    3.23 gear with those tires is just plain dumb.
    https://www.dennysdriveshaft.com/pot...alculator.html
    5600 RPM, 3.23, 31.91" is...
    1st/3.06 53.8 MPH
    2nd/1.63 101 MPH
    3rd/1.00 164.7 MPH
    A reasonable gear for that tire size, 4.11, gives reasonable WOT shift speeds of 42, 79, 129, and a just about perfect 2000 RPM cruise speed in 4th of 66 MPH.
    Dec 2022
    20
    Ya luckily I don’t tow with it just daily commute. Come late spring I might head out to the junk yards to look for a sierra Denali rear end or v max truck .
    Sep 2021
    475
    Make sure the speedo calibration in the tune matches with bluecat. Dont forget to set your shift lead time in bluecat, usually for a 60e i use 1 or 1.25.
    405
    2,326
    You should use 31.1 for that tire size.
