Having an issue with startup.
1962 impala mendoza updated prime pulse.hpt
new timing and new injector data.hpl
Usually starts when cold on first try. When it starts getting up to temp it takes a second try. Then when it is up to running temp it is very hard to start.
things i tried
1. moved idle timing and startup timing
2. moved prime pulse up and down
3. moved first pulse up and down
4. moved second pulse up and down
5. changed the fuel injector data a bit to what another tune had that i could find.
6. moved cranking ve up and down. can tell when it gets rich for shure.
Runs good other wise, after it cranks.
