Results 1 to 12 of 12
Thread: Transient - min fuel milligrams
    Am I the only one that can't access the min fuel mg under the transient tab? I have updated to the latest version and it isn't showing for any tune file.... I'm sure I'm not imagining it being there
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    522
    Quote Originally Posted by VXSS View Post
    Sounds like you have Basic view selected instead of advanced.
    Edit > View > Advanced
    7,649
    That's a Gen 3 thing, isn't it?
    Feb 2018
    826
    Yeah, I think you are right
    My view is set to advanced. So nobody else has this issue?
    Nov 2017
    1,467
    I think blindsquirrel is suggesting that's something used in GEN3 but not GEN4.
    Hmm I'm so sure I have adjusted this before in gen 4s
    Aug 2010
    Detroit, MI
    932
    There is a similar cal in series 8, but it doesn't work exactly the same way as the min fuel milligrams cal. What are you trying to do?
    I'm trying to reduce a rich decel. I have dropped the minimum pulswidth under the fuel tab and its not too bad but I'm sure in the past I have adjusted the transient - min fuel milligrams also
    Aug 2010
    Detroit, MI
    932
    If the tip-in isn't lean at all (and everything else is fine, hardware in particular), then increasing the accel/decel ratio table can help that.
    I will give it a shot. Thanks
    Can anyone tell me if the maf tables are referenced even with no maf connected running olsd? This thing just refuses to pull fuel at decel at times. Can get down into the 10s seems to be inconsistent about it though
