Results 1 to 15 of 15
Thread: Can Someone tell me if this P59 PCM Operating System is Flex Fuel compatible?
    Hey guys. I remember reading somewhere that not all P59 PCM's are flex fuel ready because they have different operating systems. See the attached base file
    Thank you
    2005 Siverado 6L swap Scott Base.hpt
    Sep 2009
    764
    Quote Originally Posted by Musky@RG View Post
    Thank you
    ANY P59 OS can be Flex Fuel. My L31 based 383 has a non flex fuel calibration running with factory flex fuel.
    The only P01 and P59 vehicles I tune with HPTuners were ones I already had licensed. For swap stuff now, I mostly use a P59 12592618 OS on swap vehicles. I have files to literally run nearly anything with that OS.
    Get a $50 OBDLinkSX cable, download PCMHammer, download Universal Patcher. Read the PCM, Modify the .BIN file with the Flex Fuel Patch, Write the File and done.
    Feb 2023
    11
    Quote Originally Posted by Fast4.7 View Post
    I have a stock 2003 Sierra 5.3 non Flex fuel, how would I know if the stock OS can run flex fuel? I just ordered the Hp tuner so I can attempt to do this but just saw your post saying OBDLinkSx cable would work also, I don?t plant on doing anymore tuning than necessary to make mine flex fuel would the OBSLinkSX be enough for that?
    Feb 2023
    11
    I?ve got all day doing research I just realized once I posted you already said any P59 can be, does that mean that some P59 aren?t but can be made to be, or that they all come with the option to run the flex fuel sensor?
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    Quote Originally Posted by Mreddieflo View Post
    They all have the option to run a FF sensor, but HPT has not defined some tables to get it working. You can edit these missing tables via "User Defined Parameters" with and XDF that identifies these parameters. What OS do you have? I may have an XDF I could share for the FF stuff.
    405
    2,326
    I found a 03 Silverado FF truck calibration that uses the same OS that the non FF trucks use. So perhaps that OS will enable FF with just the switch. Typically they don't. What I would do though is segment swap the Engine and Engine Diag segments into your calibration bcause those are different so all the FF tables will be populated correctly. This is assuming your truck uses OS 12579405. Right now I only have it in Tunercat file format but I can load it in a PCM and read it back out with HP Tuners if you need it.
    Feb 2023
    11
    Quote Originally Posted by Pulse_GTO View Post
    Ahh that makes more sense. I could turn fFF on but would have to manually define the tables tgat I would need. I think it opens up a lot of room for user error to do it manually unless it could be copied and pasted on to mine.
    I?m unsure of how to check what OS I have. I figured that?s something I would have to check with the tuner but I haven?t received it yet. Is there another way of checking?
    Feb 2023
    11
    Quote Originally Posted by 2xLS1 View Post
    Just to make sure I?m following along right and since I?m new to this, I would have to put my engine and engine diag segments into the OS you have available? If you have it available that?d be great. Thanks
    405
    2,326
    There is a chance your main OS number will be the same as the FF calibration I have (12579405). If it is then you would put the engine and engine diag segments from the FF file I have into yours. HP Tuners software will let you do that if both files have the same main OS #. Trucks that came with FF are kind of rare. They are more abundant in Tahoes, Yukons, and Suburbans. You will have to read your PCM first to see what OS your truck has in it.
    Feb 2023
    11
    First of all, Thanks a ton for all the help! I was doubting if I should go through with this thinking I?d have a hard time getting any help if I ran into any problem and here you are helping and I haven?t even ran into any problem yet ;D
    I will wait for the tuner to get here then so I have a better idea of what I?m going to have to do. If I have a different OS I?m assuming I?ll have to change the entire OS, and from what I have read that includes having to change the vin correct?
    405
    2,326
    Don't confuse changing the VIN with changing the OS. You might not have to do either. Wait until you have read your PCM until you worry about anything else.
    Feb 2023
    11
    In the process of reading my PCM
    I have OSID 12579405
    I found the bin for a flex fuel but it?s a rwd model on the following page
    https://pcmhacking.net/forums/viewto...=6208&start=20
    Not sure if that would work or if I would need to find a 4x4 for what I am looking for since mine is 4x4
    405
    2,326
    Segment swap the engine and engine diag segments from this file into your file. It is 4x4.
    Apr 2015
    1
    Sorry to hijack a thread, but I believe this is the OS my dads 05 silverado had and it seemed to be the most difficult one ive dealt with to find a compatible OS that I could segment swap 80e into (im just using Hptuners seg swap)
    Any tips on that?
    405
    2,326
    Quote Originally Posted by fouledout443 View Post
    Any tips on that?
    05 Silverado 2500 60 4L80 with 12592618 OS. Be sure ans swap the trans diag segment too.
