Results 1 to 7 of 7
Thread: Cutting out with new MAP?60lbinjectors, file attached
    Tuner in Training biggmac4's Avatar
    Nov 2012
    31
    Hey
    Just installed a 3 bar map with 60lbs injectors and its now cutting out around 2,500rpm. I did notice once the MAP Kpa goes over 100 this happens. What am i missing?
    The car is a 2013 R/T 5.7 with a Torqstorm supercharger.
    Nov 2012
    31
    Heres the injector data.......
    Mopar 3 bar MAP sensor (5149056AA)
    Mar 2009
    S. Florida
    582
    Enable sensed MAP and see what happens.
    Nov 2012
    31
    Damn. It does the same thing
    Nov 2012
    31
    Problem solved. It was injector data put in wrong. Car runs great now.
    Aug 2017
    Quakertown PA
    481
    Thank for the update
    G3 Hemi Videos
    Mar 2023
    14
    can i get a file from you i just installed a gen v whipple on a 6.4 with 3 bar map and hellcat injectors from whipple which im guessing are 60lb injectors.
