Originally Posted by
INIVIATE
01 Silverado
5.3/4L80
3 Bar O/S
Transmission Segment Swapped
A scenario will happen where the truck goes super lean and sounds really weird. If closed loop is turned on, it kicks it out of closed loop and into "OL-Accel/Decel", except it isn't following the open loop table. The commanded AFR does not change. O2's, both factory and wideband go max lean.
All of these must be true for this scenario to play out:
In gear
0.4% or less TPS
brakes applied
1-2mph or less
Seems like maybe DFCO is kicking on at idle, but i can't find a setting or table that will make a difference.
Truck goes into PE like it should at high load conditions.
Any thoughts?
