Yes I can't seem to get my kpa's up passed 90kpa on my graph/scanner??
I'm sure it's in the os settings somewhere??
What are you trying to do?
This could be cause you are at higher altitude. 90kpa is about 3000 foot of altitude.
Could be cause the intake doesn't flow enough. More info would help.
Tuner at PCMofnc.com
Thank you for responding Alvin.
OK I'll try and explain.
On my scanner it's only showing me up too 95 kpa's. (ve-tning) The graph goes up too 105kpa's. I've done alot of runs and it's just not going past 95?? Is there something in my calibration of my map that's stopping me from getting a higher reading??
I do have another question too.
That's not how that works. What pressure you see depends on the pressure outside..where you live. on that day..etc.
What your asking is like why can't I hit -40 degrees on temperature in my logs.. Well if it isn't that outside you won't see it.. Does that make better sense?
yep
