They will fit a 5.3 with a bore notch. Factory rectangle port LY6 head will too for that matter. Not afraid of a bore notch either. GM did them factory on the 396/402s and the 366 truck engines. I have run the dog snot out of a 366 school bus engine with a blower too. 366 and 427 truck engines use the same heads so the 366s 3.935" bore had to be notched to clear the small valve 427 truck heads and the 366 had domed pistons to keep some compression. My buddy David Kauffung put 2.00" valve Fast Burns on a 305 with a bore notch and made 468 hp using 0.600" lift.
