This is for an LS Swap. Engine is a gen4 6.0L 2014, was a gen5 e78 I think; converting to an e38 from a 2014 Express 6.0. I need a pedal that will match the ECM & TB.
Will I be good with any pedal from a 2010 or newer v8 truck with a gen4 engine?
Silver 2007 Ion Redline w/comp. package, K04 Turbo, forged 9.5:1 pistons
I have an aftermarket harness and am using the GM Truck Pedal 25832864. The Camaro pedal is 22741799 but if it is used, terminals D and F will need to be swapped in the connector. My engine was a 2011 van application and had pedal 20827131 which has a slide lock connector with an adapter harness 20918117 and neither of the van pedal connectors will connect to my aftermarket harness. Gen 4 L96 with an E38 ECM.
Yes I think this is also an L96. I'll look for that pedal, thanks!
