Results 1 to 10 of 10
Thread: 99 Camaro having a cold start issue
    Hello I?m looking for the start up airflow table for the 99 software having a cold start problem now that it?s like 30 degrees In the morning if anyone can point me in the right direction, I?m at work at the moment so I cannot post up a tune
    2000 ss-stock w/ls6 intake 3.42 a4
    1985 El Camino ss 327
    2002 z28 built 347 ls1 A3
    Aug 2009
    Calibrating
    3,373
    Without file hard to say… could be fuel related and just not enough air.. I assume this isn’t a stock car anymore
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Quote Originally Posted by Ben Charles View Post
    Without file hard to say? could be fuel related and just not enough air.. I assume this isn?t a stock car anymore
    Well I really just need to know where the start up air flow table is/which one
    Dec 2019
    MS
    567
    Try starting here if your wanting to adjust the starup airflow.
    Press CTRL+N to open navigator, Type in 12146 and it goes to this table.
    Engine - Idle - Airflow - Startup - [ECM] 12146 - Idle Startup Friction Airflow Initial vs. ECT: Initial value for Friction Airflow, decay starts from this value.
    Quote Originally Posted by RDF1 View Post
    Got it thank you
    morning ride.hpl ss test idle eq ve tuningx.hpt
    ls2 bottom end
    229/244 cam motion
    ls3 top end
    92mm Holley
    99 camaro
    problem is only when its cold i tuned the start up air flow but made little difference, car stays lean until up to operating temp
    morning 2.hpl
    so this morning it was colder (38F) and it shut off on me as im pulling out of my backyard and im getting a light surge when coming to a stop or light throttle (when cold)
    Nov 2006
    2,742
    The IAC counts are maxed out in your log. The IAC cannot give the engine enough air.
    Here is a link we send to our customers on how to adjust cable throttle bodies.
    https://www.pcmofnc.com/2021/03/05/i...throttle-body/
    Tuner at PCMofnc.com
    So I should drill a hole in my throttle body? And re tune the iAC steps ?
    ss test idle eq ve tuningxx.hptmorn.hplomw home.hpl
    so i drilled a hole in the throttle body and end with a 11/16th drill bit, i got the car to start without throttle in the cold but the rpm is still hunting somewhat
