Results 1 to 8 of 8
Thread: Oem files E85 sierra 5.3 (.hpt) 2016
    Nov 2022
    2
    Hi guys,
    I need a factory oem files from sierra 5.3 flex 2016 to put on mine 5.3 gas
    Thx
    Advanced Tuner HawkZ28's Avatar
    Feb 2009
    Waverly, NE
    475
    Repository has 2. Here's 1.
    2016 53 Silverado Repository.hpt
    Hawk
    13,576
    It may show that the flex is enabled with the virtual sensor but the stoich table is 14.1 across the board, so it never actually uses the flex fuel feature.
    Nov 2022
    2
    Thanks you for this map... But i need a map with flex se'sor oem ��
    13,576
    Good luck finding one with the actual sensor.
    All you have to do is look for the 2014 Silverado file and copy over the flex fuel tables, those came from the factory with a sensor in the fuel line. There are plenty of files in the tune repository on your customer page.
    Feb 2009
    Waverly, NE
    475
    Is it similar to e38 where you have to install a physical and run the wire to the controller, and then activate in the tune?
    Hawk
    13,576
    Even easier than the E38. The K2XX trucks have the harness already down on the crossmember. I made an extension harness because I plumbed the sensor on top of the fuel tank. Enable it in the tune and away you go.
    Feb 2009
    Waverly, NE
    475
    That borders on cheating! Appreciate the info.
    Hawk
