2002
4.8l with 243 heads
stock bottom end
comp cam thumber
int .541
ext 536
duration
222 int
233 exh
42lb injectors
drive by cable
4l680e trans
tunnel intake
flowmaster exhaust
2002
4.8l with 243 heads
stock bottom end
comp cam thumber
int .541
ext 536
duration
222 int
233 exh
42lb injectors
drive by cable
4l680e trans
tunnel intake
flowmaster exhaust
Not really. Everything is pretty much specific to each vehicle.
Also saying 42lb/hr injectors doesn't help much either because there are 10 different people that may make them. Just hope that whoever you bought your injectors from that they gave you data for them otherwise you are out of luck.
