Originally Posted by
PVelaIII
This is most likely not a tune related issue however I would like some of your opinions on what I'm experiencing at the moment with the following.
Had a misfire/'dead' cylinder scenario show up two days ago. Been running perfect for the past two years, both as a daily drive and HPDE/Hot Lap Time Trial.
While coasting to a stop from the highway exit, I noticed a bit of hesitation/stumble with the engine. While sitting at the light it was obvious that a cylinder was misfiring/dead. Light load acceleration and it just stumbled as you would expect. But as you get moving it clears itself up and moves right along as usual and misfire disappears.
So, I hooked up that laptop once I got home and find the following: No Check Engine Light at any time, P3401 - Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open (Permanent)
The kicker...mds was deleted (hardware) and disabled (software) during a top end rebuild 2yrs ago due to the notorious failed lifter issue.
Has anyone experienced this before? It confuses me how P3401 would show up without any other symptoms. I pulled the spark plugs for cylinder 1 and they looked perfect but replaced them because we've all been bitten by a good-looking spark plug. The ecu is detecting an open circuit for MDS in Cylinder 1 and is disabling the ignition/spark plug.
Thoughts, ideas, suggestions before I go tearing through and inspecting the hardware, software, and wiring? I would really appreciate hearing from you all.
Everything looks good in the tune, MDS is of course disabled.
2014 Jeep Grand Cherokee SRT, 6.4L, MMX NSR-Stage 3 Camshaft kit with MDS Delete, Fuel Injector Clinic 525CC Injectors, 185 Degree Thermostat, MMX Ported Throttle Body. MMX Custom Tune.
