Oh, so you are talking about two completely different things? Still confused...
This shows up on the older PCM's I've looked at...
no they are two differnt things:
The one you see is "Trans Type", the new one will be called "ECM Trans Type"
Hey Chris I thought it worth the mention that one of the issues I had with this swap initially was hanging throttle between shifts and slow return to idle but your fix seems to have also helped both of those issues big time. There is still slight hanging but its much much better and I havent touched anything else in the tune. Not sure why this is the case but regardless, Im pleased
:cheers:
Any update on when this will be added to the beta? I would like to try it to see if it in my swap to see if I can get my speed imput working correctly to my ECU
Being worked on guys, theres about 150 operating systems we need to add the switches to which takes time.
I have this same ece/trans setup and I actually got mine to rev to redline by going in to: fuel- cutoff,dfco- cutoff rpm vs gear and changing the values for park and neutral from 4000 to 6000rpm. My car runs to redline with no issues now.
Edit: I don't know what changed but it's back to the 4000rpm limit. I got to enjoy 6000rpm for one day.
Newest beta has this switch added for all E38, E67 & E37 operating systems.
The switch works fine now but I still can't rev past 4000rpm. It's pulling timing way back like it would if it hits rev limit but that's set at 6200rpm.
How do I get the newest beta version? And will it allow me to switch from a auto E67 to a manual? And let me remove the T42?
Also can we use a T42 and E67 to run a 4L80E?
or
E40 T42 to run a 4L80E?
Any update on the changes to the beta to allow this? I would really like to get my speedo working properly. I would like get a cruise control working on it and maybe some other manual transmission options that may help with fuel economy.
same issue here on a LS3 swap with a TKO 5 Speed Manual and TBSS O.S. Tried a Write and a Write Entire with the "Manual" Switch changed over. Still doesn't wanna rev past 4000rpm. Someone please chime in who has a fix. Thanks.
Done and Done. This one has me stumped!
I dont have my tuning laptop in front of me and I havent even looked at it since last fall so Im going off memory here. How about the park limit? IIRC theres a table for RPM limit in park or something of the like? Do you have your VSS hooked up?
Ya all tables are set to 6500. Haven't driven the car yet to check VSS. Regardless w/ no VSS if Park/Neutral table if they are changed it should still rev to my limiter of 6500. Their has to be something I'm over looking. Thanks so far Cam.
Attachment 33432
In a scan of the car sitting and idling than burping the throttle it pulls ETC and Timing at 4000ish rpm.
Attachment 33433
Has anyone else had a problem with crank relearn with these setups? My truck is at the tuners but they didnt want to tune it with the vvt unless the crank relearn was working. They said theyve tried their modis scanner and it shows that im going 158 and in first gear. When i bring it back home tmw ill check to see how the vss is hooked up. I think my wiring harness guy had it wired into the vss pins for a manual ctsv using this ecu. I already had the newest beta and switched to trans type manual but it jever did anything. So those whom have gotten this to work does it still show that your in first?
