sorry that didnt work either, it was over 300 degrees off.
Post that log so I can take a look at it.
well the only way to show you would be to take a video of my egt dash gauge and the computer screen. I do think changing the enable/disable rpm for the maf took care of my lean spot. Thanks
Where was your lean spot at? Sometimes you have to add fuel in places it tells you not to too make the car run and shift smooth.
Its usually between 30-45% throttle and 2200-3000 rpm range. It was fixed from running just off the maf now
You have a log where I can see it happening?
Ill have to make a log when its not raining here
We got first rain in three or four months this week lol.
lol i wish that was the case here.
Man your fuel trims are way off thats why you get weird lean spots.
every time i tune it its always needing fuel added, I'm not sure why it keeps getting way off all the time
Post your tune from this log and also have you done a boost leak test? If you have a leak it will cause problems you can't tune out of the car.
I have not done a boost leak test, I will possibly try that today. I do have a RFL bov and it does fluctuate at idle sometimes.
I hope I can get this dialed in soon. I have a week left until I have to give my buddy the HPT module back. Also when I turn on the AC the car runs even more lean.
What brand is rfl? Also send me a pm if you want I can help you at least get your car straightened out.
heres the config and file.
See if this helps you any.
