'09 Challenger Skip Shift Disable Help
Hey guys,
I've never touched a Dodge with HP before, and have a customer that would like the skip shift disabled on his '09 Challenger. I see in the Repository that there are tune files for this vehicle, so I should have access to it with HP it appears, and I also see there is a table in the Trans section for Skip Shift. However, in a 'stock' tune file I see the drop down box is already set to disabled, however the VSS and temperature qualifiers are valid.
My question, why is the drop down disabled stock? Do you only need to modify the temp and vss values to disable skip shift?
http://i1352.photobucket.com/albums/...psczkvkzsz.png
Also, any pointers about flashing a Dodge that I should watch out for? I know when the 5th gen Camaro came out we had to disconnect the battery after a flash (initially, was corrected later on), things of that sort is what i'm hoping to get advice on.
Thanks in Advance!
