i have a 98 camaro head cam ls1 im gonna swap it to 6.0 my question is ? do i have to tune it for 6.0 before i run the car 1000km or can i just drive it till 1000km with the old head cam tune and then i tune it with the tuner?
Do you own hptuners? What would be the problem with just tuning the driveability of the new 6.0? I suppose you are driving the 1000km for break-in?
You will need to make some adjustments. Where depends on your mods.
i do have an hp tuner, and what i mean by 1000km break in because the engine is new and it has a bigger cam shaft and it need to drive it smoothly before i tune it properly.
however for hp tuner can u please guide me of what things should i to edit to make the car runs properly if u dont mind.
the car is it was tuned with ls1 ms4 cam shaft and now i swapped it to 6.0 with a bigger cam shaft so i was wondering if i can drive it smoothly with the old 5.7 tune!
I doubt its going to run or run good enough to drive it. the VE and MAF tables will probably be too far out. I could be wrong though.
Just got done doing a lq9 swap in a 99 fbody. computer was tuned for cam swap and a few bolt ons. started right up and drives fine but leans out on WOT and havent even touch computer yet.
