Originally Posted by
oldskool
What if the pcm is pulling back WGDC? For example, like you said, I want 24psi flat, and on my set up it takes ~74-76% WGDC to get there, then after a couple pulls, It's winding back WGDC to 72% in some cases - giving me ~22psi.
Also, as i mentioned, my car has the GMS1 3-bar maps, calibated properly, so I'm not running anywhere near outside what my sensors can measure. My boost limit is set at 26 psi (275kpa), and my pressure ratio table is also set to 2.75 for now (which realistically, being in the desired boost section of the torquemanagement, should be commanding 26 psi lol).
I just feel like the problem is the desired boost - because if I dial everything back to run 22 psi, it seems consistent and happy. I'll have to upload a tune when i get home to see if I'm missing something obvious.
