Can a Fast wideband O2 be set up as a lambda sensor? I just got calibrated success, and I am trying to get set up to use it. I have a FAST wideband, but I don't have any info to set it up as a lambda sensor
Thanks in advance
Tony
Thanks in advance
Tony
My LC1 allows you to output either AFR or Lambda, so I don't see why you wouldn't be able to do the same with the Fast. Check the program options.
I think I found the correct values to log a Fast wideband as lambda, since the O2 sensor is a Bosch LSU4.9. This is what I found:
http://i215.photobucket.com/albums/c...t/e0ba68fd.jpg
So I entered the values like this:
http://i215.photobucket.com/albums/c...vet/LAMBDA.jpg
Figuring Lambda at 14.13 IIRC to account for E10.
Does this look correct?
Tony
