1 Attachment(s)
stalling at idle
i have an occasional stall when i stop or put the truck in reverse. i tried searching the forum but the search function is giving me errors. i am taking her in for dyno tuning over the next few months but it is something i would like to correct until then. other than eating fuel and being rich as hell i dont mind how it runs until then. here is my tune as it sits. it was set up by the tuner because i had a bad CPS and we couldnt finish tuning. thanks for the help.
provide some detail on engine and setup please
Ed M
LS383, PRC stage 2.5 5.3L heads, comp 228/234 @.585/.595 112lsa, 11.5:1 compression, NNBS intake,FAST 57 lb/hr injectors, 90mm edelbrock TB, ARH long tubes, high flow cats, jakes stage 3 4L80E, circle d 3600rpm stall, 4.10 yukon gears, tru trac,
greasemykey.....mate what sort of car is it? just had a look those underspeed/overspeed tables are those stock and how does it idle or how well does it idle?....the ve map down low in idle conditions looks lean to me......I don't know much about you fuel set up but the injector flow rate don't look right......if you can post up a scan so we can see what is happening when the problem occurs mate...cheers Bret
