Trying to log and flash my car but I can't get them to connect .iv reset my computer ,checked fuses and all . I have nothing but problems like this .what is the issue?
Has it ever worked?
What version of Scanner/Editor are you using?
Here's the easiest way to check things... Just plug in your interface to your laptop - does the little green light, light up? If so - you have a good working connection to your computer... Now plug in just the interface (unplugged from the computer) to the vehicles OBD port, does the little green light, light up? If so - you should have a good power feed from the vehicle - now do a key on - does the "I think it's a second light" blink? If it does then you should have a good communication network to the vehicle...
I imagine yours isn't going to light when you plug into the OBD port - look for a cigar fuse or lighter fuse in your fuse blocks "most likely blown"...
If everything shows to be working, what version of HP are you using - 2.X / 3.X? If using 3.X, have you updated your interface? AND do you have all of the correct drivers installed? HP list one of them on their website, but I think this one automatically installs now anyway?
Anyway, just some quick things to check before contacting support...
Yeah iv checked the green light on both ends to make sure the box was getting power . I'll check to see if the other light comes on . I have the Bata software it's all been updated about a month ago .I flashed the car with a tune on it then now it won't connect or log .does this shit to me all the time .now I have a engine light on and I can't even see for what
Why are you still running the beta? I would use the latest software
that's what my tuner uses he likes it more idk. I got the scanner to connect once and now it wont again .
Again, what version?
Have you tried the latest version?
