can you tell me how to lock the car in 3rd gear for my dyno pulls? I have the autostick set to not upshift and I have the TRANS-AUTOSHIFT SPEED-WOT upshift maxed at 2-3 and 3-4 and 4-5 but it still shifts into 4th fom 3rd.
Shot you a PM but for others with the same question:
Make sure your TCM rpm limit (Trans>General) and all shift points are ABOVE your rpm limit set for the engine under the Engine>Fuel>Cutoff, DFCO> Rpm Limit Drive. This will mean you will tap off the rev limiter before it'll shift.
