GB DVD green tops data issue issue
Ok I paid for a tune with this injector data. The tune had a LOT of KR in it so I had to make some changes.
I will admit that no matter what OTHER injector data I use even starting from a stock file will even run without sputtering. I have gone through the DVD and set it up right im pretty sure as I have compared it to others with these injectors and the data is very similar but none of them accelerates as well as THIS odd data. I am asking WHY?...
This data runs smooth but idles high sometimes like holds at about 1450...and idles a little rich. I now finally have my HPT back from service and my LC1 wideband. So I will be doing VE tuning as soon as I can get off work and wire it up and figure it out. I want to get the injector data right first though. The car runs pretty strong no bucking really even with a big 25x cam.
11:4:1 compression 408 with a 250/25x cam, 1 7/8 headers ported fast 92, 3" x pipe, avg 62psi fuel, tick mc, spec, ford green top 42lb injectors, asp pulley, racetronix hotwire kit, ls6 valley cover, 90mm tb, (78mm Granatelli MAF) I know i know its killin me but for now im just tryin to get straight enough to go SD, vararam with power duct, NO EGR, 160 stat, NGK TR6 plugs...other mods but none that matter for this question.
I have a lot of nitrous stuff but only the plumbing for the DP is installed. Right now im just trying to get the car running decent.
Here is the current tune and a few logs. This is on a 1997 Vette.
[email protected] is my email if anyone has any insight...
Thanks in advance guys
stock file pulled before I did anything.
However come to think of it im not sure if its an unmolested file... I wasnt the first owner of this car. I compared it to another stock file from the repository just now and saw minimal differences when it came to fueling.
Quote:
Originally Posted by
69lt1bird
It would be nice to see your stock tune because the voltage table looks waaaaay off fro your injectors and your IFR is too low also.
