2 Attachment(s)
Newbie Tune help 02 corevette procharger
Hi,
I'm trying to track down a gremlin in my current tune. The car was re-tuned for my 60lb injectors, racetronix fuel pump/hot wire kit, and long tube headers. After the tune I'm getting a hesitation at low RPM and engine under load ( slight grade on highway or on ramp). I logged it and I'm seeing knock retard. I have thrown a P101 code at times as well.
My mods are Procharger with 9psi., long tube headers, racetronix fuel pump with hot wire kit, 60lb. injectors, and currently disabled for troubleshooting a AEM water Meth kit.
The MAF is staock and descreened.
Reading the log I'm concerned my timing might be too high at the low RPM but don't want to pull timing just because.
Attached is the current tune and a scan of the P101 when it sees KR and throws it. The code is at the end.
Thanks for any help and/or insight.
Tom
