Why does my ZO6 only report a throttle percentage of 85% at WOT?? Why shouldn't this read 100%? I know that some of the parameters look to see at minimum value to activate certain modes but isn't this parameter raw throttle opening?
Howard
Howard
You need to log ETC TPS Position, not Throttle Position.
Russ Kemp
Yep, what he said. But it should read up to 88% if reading the TPS, so maybe your floormat's in the way. ;)
Nope, you guys are right! Saw 88% today while logging on the dyno!
The % TPS (SAE) is the % of 5 volts that the TPS is reporting. If you're at 4.4 TPS volts you are at 88% TPS (SAE)
