VCM Scanner and Credits Question
Does the VCM scanner work as a regular scan tool where I can use it with any car... or does it only activate for the car you have activated with the credits?
Also does the VCM Scanner allow you to run some of the tests that the manufacturer scan tool can run? Like can you toggle the ABS system and run some of the tests?
Temperature Edit/ Oxygen /speed Dis- Able
Sir,
My firend has an existing HP tuners suite with a basic credit (purchase direct from states
In case we made to modify the Temperature or dis-able the oxygen sensor or open speed gm/ford vehicle do we have to had a credit licensed.
Orthis credit licensed applied only once you made a pcm,vcm flash or programming.??? Well since they purchased this unit up to now they dont used it .
Techno
