More custom PIDs
Can we get the ability to define more custom PIDs? Currently we are limited to ten, and the first three can't be edited. I am curious why there's even a limit, but it would be great to be able to define more especially with so many different platforms supported now.
Adding more analog input custom PIDs would be awesome too.
Can we start a chant. We want this...we want this...we want this.
Fifth'eded. Def. need to be able to add more than 7 real custom ones
Not to mention a better way of managing user defined anything. Why can't I drag fields that show in the primary table to wherever I want them? Now I have to delete them, right click in the right spot, go find them again, and add them back.
Same thing for moving things around when editing the charts view. Should be able to drag items from one chart to another without having to delete/recreate it in the other chart
Also, instead of having to go to Insert to get to the list of things I can add or edit, then having to select the user defined option, then changing them, why can't I just right click on on the primary table and it have an edit user defined fields or something like that in addition to the insert/delete options?
Also, in the current setup, it would make more sense (to me) for after you're done configuring a user defined parameter and hit the X for that menu, it should go back to the "insert PID's" menu instead of having to have the extra step of right clicking-->insert again
That's all that comes to mind right now
edit: OH, and in histograms, add some keyboard shortcuts for the last/average/count views (L/A/C perhaps?) to make that easier to cycle through while logging on the road.
One more. Make keyboard shortcut so that hitting 11 will go to histogram, 12 to 12. Right now 1 through 0 work for 1 through 10 great..but the last two would be nice to have shortcuts for as well
Ok, one more. Maybe I should make a thread. When you make a custom parameter and you end up using PID's that aren't being logged currently, you get some kind of error about unsupported blah blah blah, can't remember the exact error. Why not have it log what it needs to log automatically instead of having to add each one manually? I fought with this for a while in the beginning, finally figured it out
