2 Attachment(s)
Problem performing Crank Relearn
Attachment 59426Attachment 59427
I have a 63 Nova that I can not seem to get the crank relearn performed on. It Has a 07 6.0 out of a van with a fast intake, small cam, BBK TB, headers and 42lb injectors. The computer is a 0411 out of a 2001 suburban. I got it running in Speed Density mode but it looks like I can not do the crank relearn in SD. So I tried to do a setup for closed loop. The car will start for a couple seconds and shut off. The only real difference between the setups is the enabling of closed loop. Can anyone look at my two setup files and see if anything stands out why it will not run in the closed loop setup. Thanks for any help
