1 Attachment(s)
0411 PCM PWM Fuel Gauge Output help
Hey guys,
I have a 6.0L LQ9 swapped into my 85 camaro, it has the 99 LS1 intake, 0411 pcm, and a 99 camaro fuel tank/sender/pump.
It also has the stock 85 gauges.
I found these settings in hp tuners, that say i can drive a fuel gauge using pwm.
Ive tried searching and searching for info, but i am confused. I've seen alot of old old threads saying you need a segment swap. Im assuming these features have been since added to HPT and that is no longer the case?
I need to know which pin I plug my fuel gauge into. From there i can play with the settings and make it work.
Thanks,
Socks
