Whipple Tune - Is it full flash or cal only?
Hi, wondering if the supplied Whipple tune they send out on the Super chips programmer (in the kit) will be a full flash or a cal only flash. Based on the notes at the bottom, it may just flash the cal info since it says the cal has to be stock. If it was a full flash I would think it wouldn't matter what's in the ECU unless it reads it, apply's the changes, then writes the new tune.
Reason I'm asking is the kit is prob. 3 weeks from getting here and I just got 2bar support thanks to the latest 2.23.731 update so I want to start tuning that in (VE tables, etc) so when the Whipple kit gets here I'll be ready for it.
I was thinking if it's cal only i can just flash the PCM with the whipple tune, then copy it out and apply some of the changes manually to my 2bar tune.
I don't want to have to copy the Whipple tune and re-apply the 2bar enhancement and spend more money if I spend money doing this to my tune right now.
Notes in the Whipple Instructions:
Your computer must have a stock unaltered file or programmer will not load.
If you car has been tuned you will need to return it to stock before proceeding
If you’re unable to return it to stock you will need to take it to a GM dealer and have them update the computer.
