when I was using 2.24 I had a histogram that logged the wideband afr against maf freq. I'm not seeing anything comparable with 3.2. am I not looking in the right place, or am I looking for something that is called by a different name in 3.2?
I made all new ones but I think 3.2 converts your old histos for use in 3.2 but not 100% sure, probably incorrect on this. Here's a vid of setting it up.
https://youtu.be/F1VWfwmic1E
http://www.hptuners.com/forum/showth...tarted-Threads
http://www.hptuners.com/forum/showth...er-V3&p=419231
Use AFR or EQ Ratio error or whatever parameter you want instead of LTFT+STFT as needed
I saw those earlier, but I don't know how to use the afr error method. If I tried to use it, would it be explanatorey enough for me to figure how to use the data?
Post a log and your current layout and I'll add some stuff for you.
