Brake problems after cam swap 5.7/6.4
No TUNING QUESTION !
2012 Dodge RAM 1500 LL NGC4
Cam swap to 6.4 and MDS delete.
Brakes are completely new, brakelines, brake booster, ABS block...because of this failure.
Wheel sensors are all same data, so no ABS problem.
The car has ABS ESP but no active brake system.
Problem is, the brake pedal needs only a light foot and it responses quickly, like the brakes are under preload.
When driving under cruise control, the brakes comes lighly in and overheats.
Now my question...
Did the cam this in cause of lower MAP pressure - by wider LSA - and get the brakes in ready conditions ?
Or is it the higher vacuum for the Booster - but I think not, because Ive disabled the booster vaccum once and the brakes didnt release.
