5 Attachment(s)
Help a Newb Out That is Probably In Over His Head
OK this one will likely be a long one so grab a frosty beverage and settle in...
I have an 07 Cadillac CTS V with the following drivetrain mods: TVS 2300 Supercharger, Deka 60 lbs shorty Injectors, LS7 MAF, Omega Thermistor Mod, Heads (GM LSA ported & polished – home job), Cam (218/238 .598”/.615” 12- LSA +2), Kooks 1 7/8” Headers (wrapped), DW 300 Fuel Pump, Kenne Bell Single Pump Boost a Pump, 18 lbs flywheel & MacLeod RXT Dual Disk Clutch, and Tick Master Cylinder
I hired a professional tuner with a very good reputation to tune the vehicle as I new this would be a difficult tune (all mods installed simultaneously and the E67 PCM). The results have been interesting to say the least. The dyno numbers are outstanding (roughly 650 HP at the wheels) but the car only runs well (well at this point is defined as without knock) on the day it is tuned :( After reviewing the tune, attached, I think I know why.
Attachment 44186
Attachment 44187
Attachment 44188
Again I am just a newb but I expected to see the injector data for the Dekas and the MAF entered along with "scaling" of the tune. Maybe I am just too much of a newb to recognize the changes but I don't think so.
At this point I believe I need to start from scratch and have prepared the following first cut.
Attachment 44189
The following is the rationale for the changes included in this tune:
Edits for general good practice
OS
-General
--General
---TCS Patch
---TCS Patch 2
Transmission
-Manual CAGS
--General
---CAGS Min Coolant Temp
System
-Fans
--General
---Fan Desired % vs ECT
Items adjusted for LS7 MAF utilization
Engine
-Airflow
--General
---MAF Calibration
----Airflow vs Freq Low
----Airflow vs Freq High
Items scaled because of injector size limitation in PCM (65% Scale Factor Used)
Engine
-Idle
--RPM
---Proportional
----Airflow
---Integral
----Airflow
---Base Running Airflow
----Airflow Final Minimum
---AC Airflow
----AC Ramp In
---Cooling Fan Airflow
----Low On
----Med On
----Hi On
----Hi Off
---Transimission Shift Airflow
----Drive Step
----P/N Step
---Startup
----Startup
---Throttle Follower
----Airflow Step Down
----Airflow Step
----Airflow Max
-Airflow
--General
---MAF Calibration
-Fuel
--General
---Flow Rate
----Flow Rate vs Press
---Offset
----Offset vs Volts vs MAP
---Pulse Corrections
----Short Pulse Adder
---Limits
----Min Injector Pulse
--Cutoff, DFCO
---Cylair
----Enable
----Disable
--Open & Closed Loop
---LTFT Purge Cells
----Reduction
Items Changed to use Edelbrock Supplied Bosch TMAP
Engine Diagnostics
-Airflow
--MAP Sensor
---MAP Sensor Linear
---MAP Sensor Offset
Items Changed to use Omega Thermistor
Engine Diagnostics
-Airflow
--IAT Sensor
--IAT Sensor Curve
Items Changed for Handling Increased HP
Engine
-Torque Management
--General
---Trans Input Torque Limit
---Trans Output Torque Limit
--Traction Control System
---Delivered Torque Max
Speedometer
-Limiter
--General
---Speed Limiter
---Speed Limiter 2
Items changed to support Tick Master Cylinder
System
-General
--Clutch Interlock"
So now to the question. Does anyone see any reason why this isn't a good first cut? Also, in trying to get familiar with the Bluecat tool I imported the stock CTS V LS2 VE data. However, when finished I ended up with the following:
Attachment 44190
I am guessing I did something wrong because of the large deltas in the data but I have tried this multiple times. Any pointers to get me rolling in the right direction?
For those who might suggest that I take it back to the tuner - He has made two attempts at tuning the vehicle and this is the result. He has had the car for seven weeks during those attempts at tuning (he did two more mods fuel pump and clutch - I later had to redo the clutch - dragging). At this point I cannot see wasting more time with him.
Thanks in advance for any help you can provide.
