4 Attachment(s)
Buick 3800 V6 Rock Bouncer - Tuning info
Well I thought I'd post up a little about my project. Hopeuflly, I can gain some insight concerning tuning a setup like this
Series II 3800 with 8.0 comp Diamond pistons
Iron cylinder heads Heavily worked over (all you can do) with 130# valve springs
powdered rods and ARP everything
camshaft is a turbo cam specs--- duration @ .050": 226º/218º, lobe lifts: .343"/.346", valve lifts with (stock)1.60:1 rocker arms: .549"/.553", lobe separation angle: 116º, intake centerline: 110º
running F-body intake setup
my turbocharger is a Holset HE351v varible with a 60mm compressor wheel
the exhaust housing will go down to a 3-6cm and opens to approx 28cm
Intercooler good to 600Hp (as advertised )
Fuel injectors are Racetronix 120# and have AEM injector driver modulue and harness
Running a Fix frequency Mini AFC
I am using a wastegate actuator to control the opening of the turbos.
I have a TiAl 38mm wastegate and a 50mm BOV
My goal is 650 Horsepower with hopefully near INSTANT spool.... I have a 3000 Stall I'm using a Full built PTC th400. My axle ratio 6.72
I am using Hp tuner
What I haven't gotten and would like recommendations on -
* Inline fuel pump
* Fuel rails
* which throttle body ( All my stuff was 1997 )
* MASS AIR (stay stock and rescale?)
I have no info on the injector driver setup as to how to 'tune' for it... Help appreciated
Below are a few pix of the general build...
Any comments would be appreciated and THANKS!!!!
