Tune Safety Question
Generally speaking I dont mess with knock sensors, burst retard, recovery rates etc... but I'm trying to build a generic safe tune.... Just as a power up. So essentially a bit of a hack ........
Here's what I got....
Stock:
PE TPS 43% .... mostly across board, MAP 15 etc
Enrichment Rate: 0.0100, usual delays
Fueling: Ranges from 1.1 starting, ending at 1.23 etc....
I cant give too much away obviously otherwise people will know the basics but....
My Base Changes:
PE TPS dropped to 3% across board
MAP 70 no delays
Fueling set to 12.54 top end
Now my question is this:
I have doubled recovery rate, halved knock attack base, and desentisied the knock sensors by 1% from 1000rpm at 30 g/sec
Do you think this is a safe power up? From my scans the margins GM sets are probably way safe....
I constantly get knocking at cruise.... nothing i do fixes it, so I figure desensitising slightly is probably best, no audible engine ping etc.
