Engine TM on C6 A6
I have a 2006 Corvette C6 with an auto transmission (A6 - paddle shift). I just pulled my first read with it.
In VCM 2.1.12 I see some TM options in the Engine section (Engine > Torque Management > General > max torque) .
If I raise the values to the max for each of the gears. Will that eliminate the TM (at least for the engine)?
Also on a side note... if I want to post the file (.hpt) to the repository for users to use, is there anything I need to strip out to be safe (i.e. my vin etc)?
Yes,
The engine management TQ can be disabled per gear now just like you specified.
You can't strip the VIN from the cal..
C6 A6 Tuning
I did not think the C6 A6 could be adjusted with the present version of HP Tuners. Keith confirmed this yesterday by email. Is there a hack or work-around out there?
The engine can be modified, not the transmission. So if you reduce the Engine torque management you won't have spark, fuel, or ETC reducing the engine output.
