S10 with 5.3 swap won't let me license
Got a buddy with a 5.3 swapped 2000 s10 and 411pcm. Issue is when I try to license the current tune so we can change a few things it says "send file to hpt os/vin do not match" is what it said I do believe.
He had initially sent the pcm to someone to have the tune setup for the right motor/trans/headers/intake/rear end gear. They also entered in the s10's vin into the file.
When you hook the scanner up it says its a 2000 s10 truck with a L4 still. In the OS it says it's a v8 at the same time.
What's going on here, and how can I fix it to where it will license and let us edit the tune.
Posting this from my phone currently I will attach the tune if need be later.
