1 Attachment(s)
Dyno flatlines after 5500RPM
I'm kinda pulling my hair out on this. I'm under the impression that there's something wrong with the tune, and/or parts selection which is causing the HP to flatline after 5500RPM. I'd like to collect whatever data logs you deem necessary to help isolate if a problem exists. Voltage remains around 13V at WOT through fuel cutoff, fuel pressure is about 60psi until the upper RPM's where it drops to low 50's. New plugs and wires a few months ago. Compression test in September gave results of 200-205psi on all cylinders. Could it be a valvetrain or lifter issue?
Prior tuning was first done by Frost mail order, then touched up on the street using NGK AFX & AFR, then touched up on a Mustang dyno, then touched up again using lambda because the AFR tuning was wrong according to feedback here. Most recently I made a group of 10 calibrations, the only difference being a PE EQ Ratio mimicking 12.0 to 13.0 in .1 steps. I used that to determine which EQRatio gave the lowest elapsed time between RPM ranges and between speeds on a long level road. Only tried up to 12.6 though as I ran out of time and read that LS3's like it a little richer anyway. Intended to do the same thing with advance but never got around to it.
http://i808.photobucket.com/albums/z...latestdyno.png
Thank you for any help you can offer.
