I also had this issue. It seems I had to run the install from the command prompt(make sure you click on the button that says to run as administrator). Once you have navigated to the right folder, make sure you use quotation marks as the file name has a space in it. I am not a coding guy, but can follow instructions others have provided, use tech support, and stumble to find my way...This is what worked for my situation. See photo...replace the username with yours:)
Attachment 142906
I also had to remove Onedrive a couple of times as the computer kept adding it back. So immediately after uninstalling Onedrive, I ran the program from the command prompt and was able to install...hope this helps a few of you guys:)
