2 Attachment(s)
5th gen ZL-1 issues after cam swap
Okay this is my first time posting on here but I'm struggling to figure this out. I currently working with my tuner to tune my car and I'm fighting a lean condition at idle. I've checked all of the vacuum lines from the intake tube all the way to the crankcase cannot find any leaks. Also did a smoke test with no luck. I've checked my exhaust for major leaks with no exhaust leaks.
All of this is after we swapped in the BTR stage 2 cam kit and the tuner I am using tuned the car before and we did not have this issue. Below is the list of mods on the car also including the latest datalog and latest tune file. If you notice in the log the IAT's are high because I had air in the lines so the pump went into fail safe mode. That's good to go now.
2014 Camaro ZL-1 / ID850 injectors / BTR Stage 2 PDS cam kit (titanium lifters, harden pushrods, dual valve springs and retainers) / Longtube heads with xpipe and catless downpipe / Cold Air inductions Intake / JMS fuel pump boosters / Innovative wideband.
Any help is appreciated!!!
