How would I decrease the upshift times? 1-2, 2-3, etc...
There use to be a "Desired Shift Time - Base Upshift" column but not in the L99 Camaro.
Should be a table in Shift Time called Shift Time Inertia adder - Upshift Normal and decrease the values around 15-20% at a time until you get it about right for your desire and decrease 5% from that or increase 5% until you get it right. Takes some time but it'll be worth it.
Hope that helps.
Actually I have shift time torque adder - upshift normal.
The only Inertia table I have is the Inertia Factor Profile Upshift under the Shift properties General tab.
Here is the stock file.
