Not sure why you guys are bumping this, compile hasn't been done yet, once its ready I'll post that its been compiled. I have a few guys that have emailed me to be put in queue for the tables and I'll be emailing them as soon as the compile is done.
good hopefully by the time i buy my stall next month this will all be done
any updates on when is going to be released?
the new tables will be great.
i have posted up on this before. the current pressure tables seem to have no effect. i am logging the actual main line pressure using a pressure transducer. there are times when the main line pressure seems too low, as low as 100psi. that is likely not enough to hold the lock up locked on a high hp car.
i have tried playing with all of the line pressure tables and they have no effect on actual line pressure.
any ideas on this?
I definetly want to get this fixed on my G8. I have a FTI 3200 waiting to go in
Having a problem with the twin turbo I am working on. It keep slipping the clutches or just dropping out of gear when at WOT or heavy part throttle under boost. It does it in manual, drive, or sport mode. If you look at the graph, at the 6800 spike the MPH drops off just before and converter slip goes from 660rpm to 140rpm. Tried raising line pressure but it doesn't help. Could be the same issue you are referring to Parish.
no, i dont have whatever issue you are having.
can you put current gear on that chart and post it up again. i see you loged it but it isn't on the chart. also what size injectors are you running? i had a hell of a time tuning for scaled injectors. it was messing with my tranny tune.
bump is this released yet? Have a timecrunch for it! :)
I'm sure you didn't see post#23 :)
If they don't get something soon, just remember there is another option. I too would like to get it and compare to what I have.
Hows that compile coming?
I'll make a post once its ready.
Thanks Bill
Question for you guys with aftermarket single units.
I know we should disable lockup at WOT on those single units, how about lockup at cruise speed to prevent the pulsation everybody feels with aftermarket verters ?. in the G8's lockup is commanded in 4th,5th and 6th in cruising areas. since the aftermarket verters doesn't like the slip commanded by the TCM, is it a solution to prevent the verter from locking while we get access to this new tables ??
Or should we just leave the lockup the way it is in those areas, while still disabling the WOT lockup ?
Thanks.
I'm running a Yank SS3600 in my 2007 LS7/A6 Corvette and that's pretty much what I do which is leave it off at WOT and don't have it kick in until around 65MPH in 6th gear. It's set up like that in D only so it behaves normally in S mode in case I ever want to have it lock up earlier.
Got it, so you apply in D only, 6th gear where mph >65, my guess is that the release also happens at 65 in the same mode ?
Great, Thanks a lot.
