2011 Raptor 6.2
P1Sc
Built trans.
Let it shift into 4th - stomp WOT, literally 2 second delay. Log attached at 1:00 mark.
Tune attached.
Any ideas? Haven't ran into that before.
2011 Raptor 6.2
P1Sc
Built trans.
Tune attached.
Go into your torque management down shift section in transmission and increase the bottom 2 rows by 80 to 100 lbft in all tables it should help fix the delay I see your values are still stock. Let me know if this helps there is more you can also do to make it down shift faster but you don't want to make it shift to fast. The Trans needs time to have enough fill to apply the requested clutches, not having enough pressure to hold the applied clutches can make them slip.
