Logged data on AiM Solo2 DL doesn't display (AiM Sensors) in RaceRender
My setup:
AiM Solo 2 DL with AiM ACC with 4 channels with 3 AiM sensors.
Channel 1: AiM Sensor for Water Temp
Channel 2: AiM Sensor for Oil Temp
Channel 3: AiM Sensor for Oil Pressure
My AiM Solo 2 DL displays the readings on the unit itself. The logged data is also available using the AiM software. However, when I try to display these through RaceRender, only a static number displays. The AiM sensors are correctly mapped to the right channel within RaceRender. I wanted to compare the stock readings from the AiM BMW_mini ECU set vs the AiM sensor readings.
Is there something additional I need to do? The readings from the AiM BMW_mini ECU set display correctly. I just can't get the AiM sensor readings to display. Both the ECU and AiM sensors are using the same RaceRender object, but with different mapped channels.
