Spark swing by 20 degrees during light load takeoff
hello, I have something confusing going on.
light accel takeoff I can feel rpm swing a bit and see its due to timing bouncing around. no knock retard is happening.
in the log I see its happening around 16mph, and 6mph so I dont think its idle timing.
to make it easier to find the info in the tune, these are where it happens:
it jumps from 12 degrees to 35 degrees at 17mph slight accell, and back and forth as seen in the pic. time in the log file is 5:33.266
rpm-----g/sec-----actual timing------idle timing-----Main Timing
965-----0.24 ------12 degrees-------17 degrees----33 degrees
1047----0.23-------35 degrees
another area going 7mph it showed -4 degrees then 22 degrees, idle spark is 13 degrees in this rpm/airflow.
can anyone help??
thanks
