Only thing that shows up for speedo calibration is final drive ratio max and min what does that do??
if the out of the box device programmers can do it there must be a way
does anyone know if adjustment the gear ratios for the transmission will effect the speedo output?????
theoretically i could change the gear ratios in the trans to compensate for the tire size difference if it was part of the calculation
maybe if you start a couple more threads on it...
I only started one. This forum is dead
Did you ever test changing the transmission gear ratios?
