VCM Scanner 2.25 Ford Tips
Since 2.25 Scanner is now in Beta and I am actively adding more and more parameters for logging, I figured it would be a good time to start a thread about the updates.
If you have already tried 2.25 on your Ford, and are not noticing any new parameters for logging, you may need to make the software repoll for supported parameters.
To do this, delete any files you may have in My Documents\HP Tuners\VCM Scanner\Vehicles
Whenever you connect to a vehicle for the first time, the software polls the available parameters and writes a file into this directory. After that, it always looks at the file for supported parameters (as to not waste time repolling everytime you connect). So if I add new parameters, the software is not going to check for them until you force the software to re-poll.
This past week, I have added DMRs to several different strategies for testing. I have also added a ton of new PIDS for Copperhead, TC-1791, and TC-1797 PCMs.
If you have access to a vehicle, please take a moment to check out all the new stuff, and report back what doesn't work, or is missing.
