For a 2004 Z06. Is this not available for this application? Using v 2.24.
Looking for 'Fuel to wall impact factor vs. cool temp vs. map'
TIA
TIA
I just noticed that this table is on a stock file (not my stock file) but not on mine. If anybody has any input as to why, that would be great. Otherwise, I'll just have to transfer all my changes to this stock tune, use up a license and reflash. I'd hate to have to do that.
post the two files in question and I'll take a look.
Here you go. Please let me know what you see.
TIA
If its in there we were unable to find it in the code.
Hmmm. I attached a screenshot of it in the stock file.
Code changes from year to year, we looked for it in YOUR file but it wasn't in the same place as in the other one so gm may have moved it or completely removed it.
Ok, thanks for checking.
I should be able to use the stock file and transfer everything over and flash without any issues; correct?
Just want to be sure.
TIA
You probably have what I call a red/green pcm. Not a standard 411 red/blue pcm. I've seen it on 04's before and their OS's are ridiculously dumbed down. VE resolution is crap. It's bad enough for me to warrant changing PCM's to a older 411 and load a better OS in it.
Found a little info about the 411 red/blue PCM.
http://www.pacificp.com/forum/viewto...6be14b55e9099d
http://www.hptuners.com/forum/showth...e-12200411-PCM
^^^^ may be the answer. I don't do much in the truck world.
