([50010.242] > 130) (40 > [50091.156] < 10)
does this look like the correct filter for recoding ltft+stft over 130 degrees ECT and anything between 40% and 10% throttle?
Thank you for any comments
I think you'd get similar results just by filtering out anything that isn't EQ=1.
[50118.239]=1 (or whatever PID your system uses for EQ ratio)
[50010.242]>130 and [50091.156]<10 and [50091.156]>40
looking back through some older posts, blindsquirrel, with your comment of eq=1, is there a chart i havent seen that shows different 'zones' such as your example?
Searching i found this back in 2010, but i don't think you are referencing this example?
0 = idle
3 = heavy throttle
1 = decel
4 = moderate throttle
2 = everything else
