Right on, ya you just did the conversion for the formula. Pretty slick. gotta love the HPT logger. I can't wait for it to be released for 2.25
frequency=1/T(or period)
My SCT X3 device won't let me log via my laptop unless I have it loading a custom tune on the car first -- is this what you're doing then using HPT to tune from there, or is there a trick i'm missing to get my brick of a device to log without loading a custom map first (which it refuses to do... lol).
Hmmm, not sure actually. I just know people do it. I havent actually tried.. Ive been working through the tune using the HPT scanner and its working out ok.. Still a little slow, but its somewhat useable.
As for frequency=1/T.. Remember that 1 Hz is one cycle per second, we need micro-second. Which is why my PID has that last multiplication on it.
how about MAF Volts for copperheads?
Ford tables are in Volts in the files I have seen in SCT for 2013+
MAF Frequency doesnt really do much good on copperhead stuff
Table is in Volts, and lb/min (or counts which I can get to by math from lb.min)
I was... I just noticed right below it is the same table in MAF Frequency....
they have both tables in 2013 SCT software...
I'll play around and see if they are internally linked or separate..
we havent quite got to that one this week yet.....might not be till early next week when we can get to it to tune on it
(dependent on that definition I sent you earlier as well...If I can do it in HPT instead of SCT
Eric, any update on the PIDs we were working on? I can spend some more time on the car tomorrow.
Not exactly sure how you got maf to log in hpt...for whatever reason it's not reading in mine. I went through and checked...I have nothing that recognizes mass air flow, lb/min or Hz. Also noticed that we've got some pid's for cam position...also cannot log those. I try to input them into the table and get unsupported parameter. Try logging in a histo...same story. Am I missing something? I've tried downloading newest version of 2.24 and 2.25 to see if it was something where I just didn't have the latest software. I have to be missing something, my car when scanned doesn't give me near the pid's you got from yours Eric. I've tried to make them user defined pid's as well as just picking them from the pid list...nothing. I get the general pid's for engine speed, vehicle speed, ect, iat, stft, ltft but I've had zero luck getting the "critical" parameters. Am I missing something? I've attached a sample image that shows the "available" pid's in red and the "unavailable" ones in black. For whatever reason my print screen isn't working so I had to take a pic and use that. Under the "AIRFLOW" tab all of those are blacked out as well as just about every parameter I see Eric was logging. Help.
This is what I see:
Attachment 45565
The red indicates the PIDs you are currently logging in the table display. The black represents the available PIDs. To select a PID to log, select an empty cell in the table display, then double click one of the black PID's to populate that cell on the table. You also cannot have a log file open during this process.
Yeah I know about the not having a log file open, the pic was for reference only. I'll give it a try tonight when I get home. THank you.
Wow, what a bonehead brainfart that was. I don't know why I forgot about that. Maybe because I've had my scanner setup the same way for about 6 years and haven't had to mess with it except every so often. Works great now...thanks again for pointing out I hopped off the short bus before posting. I know not what you were trying to say, but that's about how I feel right now.
One question:
When will we be able to paste special from our histo's into the tune. I got an error and beta shut down.
Attachment 45818
Attachment 45819
This is the spreadsheet I just developed for using the current pid's for lambda. It's sheet 4, the other 3 are for gm stuff.
Basically input last value, average will be relatively ineffective due to the pid's flashing negative from time to time currently, in the far right from b1 and b2, then the rest will fill in. Copy the bottom center into the wot lambda table using the paste special function. I have yet to test this, just wanted to share my current "work around" for the negative values that are being given. The weather and a minor revision of my setup are keeping me from testing currently.
You will also have to make a histogram in scanner to give you the data to input into the spreadsheet. I've also attached my scanner config as well to assist those that are unfamiliar with setting things up.
I'm not the best at explaining how to use my spreadsheets sometimes. Please if you're confused ask and I'll be glad to help.
This sheet will get simplified significantly when the negative issue is resolved, but without having a finite timetable and not wanting to push for that, I tried to figure a work around with current parameters and values we are able to see.
In order to get the wb lambda pid's to give you actual lambda you have to configure a user defined pid...taking pid.52 & pid.53 (if my memory serves) and multiply by 2,000,000,000. Yes that's 2 BILLION.
I'm still working w/ my scanner config as well, it's not quite where I want it yet.
The simplest conversion I have come up with for the MAF is this.
1000000/period = frequency
or
1000000/frequency = period
Works both ways, obviously...
Hopefully that helps someone.
Just tested the wb pid's...same tune on sct logs 0.84 avg...on hpt it's a 0.93...hopefully fixed soon.
Will Fuel Rail Pressure be an available PID?
